Everything posted by varooom
Amundsen MIB2 Firmware Update
More details please, press and hold down your Menu/Setup button for 10 seconds to enter the engineering menu, look for Software Train Yes I can send you a link very soon to 0480
8755 Software Update - Skoda Fabia 2019 Carplay Issue
@robcouch @Jop1992 I have sent you a link to download this update.
Updating Swing radio software
I will share what I think you need...
I need Bolero Update :-)
I have sent you firmware 0369, any other questions are best asked in PM.
Service
They are yours to download for life, and you an print from the PDF's too if needed. There is "ElsaPro" section that has the PDF's in a web based format, that you can view "live" so to speak, they are harder to print, but if you have spare time, look in there under what is called the "red book" (red icon) with TPI documents that you can download, if you look at my user account, you can see some pages saved from these TPI documents for viewing. For this you need to use a PDF "printer" function usually built into Windows 10+ takes a little more work to get the page printed, but not too much. Fun fact: In 1 hr you can download the ENTIRE Skoda car range 😉
Possible clutch issue
Take a look at this, mainly shows you how to read your VCDS DPF health/values. You can then see the interaction between soot and overall lifespan.
Service
Your best bet @Currymunster is to register with erWin Skoda an account, and download the workshop manuals for the car. You need 1hr access and your VIN to hand to get all the information for 7 Euros (£7.50 last time I paid) This will give you the maintenance schedule, wiring diagrams and the engine manual for the belt change (listing tool codes too)
- infotainment update
- Carplay Issue
infotainment update
They have a recovery process that will rescue then. Flash normally fails due to a bad SD Card/USB. New SD Card, and it will carry on and complete. There is the old addage of "if it ain't broke, don't fix it" so if your system seems working well, you can leave it alone. Hardest part is you won't know if the new firmware improves system operating speed by otimisation, usually it does, but a changelog doesn't exist. You can only read the TPI documents to know roughly what it fixes by reading the "customer complains of..." sections.
Dangerous tyre wear on inside shoulder
D4B802B4ACF-Axles__steering.pdf This is the name of the file for the Ocatavia III (I think this is the motor you were asking for) Let me know if you are needing values still for something.
Sadly no, I have not seen an update for this SW Train value.
Sadly this is one that nobody has seen an update for. There is MEN2_EU_SKGPx_xxxxx, but that does not match/update your software train.
Nope
Private Message sent.
@Cristiano I can send you either the correct update of 0369 version to match your 03xx version, and try to assist in activating carplay etc. Or you can have 0480 firmware, and you will be having to follow your own set of instructions as I won't assisting in changing 02xx to 03xx or 04xx versions (risk is high to break if not careful) So let me know what you wish to go with.
Skoda Multimedia Update
I can send you a link to a file and some instructions to follow, easy process.
Columbus mib1 0409 firmware
Either they didn't update it, or they didn't have enough brains between them to find the update I did. Hope they didn't rinse you for too much money.
You can update your system to 0480 version, I can send shortly by PM.
Update sent by PM
@dootzord You are running a "RW" region firmware (I read that as Rest of World) MHIG_RW_SK_P1055 - Yours Luckily for you, there is this combination release (2-in-1) [common_Release_1] name = "MHIG_EU_SK_K1552" path = "./EU" {snip} region = "Europe" [common_Release_2] name = "MHIG_RW_SK_K1552" path = "./RW" {snip} region = "RoW" SupportedTrains = "MHIG_EU_SK_P0069*, MHIG_EU_SK_P0071*, MHIG_EU_SK_P0343*, MHIG_EU_SK_P0346*, MHIG_EU_SK_K0346*, MHIG_EU_SK_P1055*, MHIG_EU_SK_P1533*, MHIG_EU_SK_P1537*, MHIG_EU_SK_K1541*, MHIG_EU_SK_K1551*, MHIG_EU_SK_K1552*, MHIG_RW_SK_P0069*, MHIG_RW_SK_P0071*, MHIG_RW_SK_P0343*, MHIG_RW_SK_P0346*, MHIG_RW_SK_K0346*, MHIG_RW_SK_P1055*, MHIG_RW_SK_P1533*, MHIG_RW_SK_P1537*, MHIG_RW_SK_K1541*, MHIG_RW_SK_K1551*, MHIG_RW_SK_K1552*" New version information, you will actually be on 0412 version at the end release = "MHIG_RW_SK_K1552" MUVersion = "0412"
Loud noise from speakers regularly
Good luck, hopefully it will be ok now. If not more investigations needed.
PM = Private Messages, should be visible on top of your screen.
You need to check PM's
