Everything posted by varooom
Columbus Sales & Repair.
But they are provided FoC by me or @pab567, I am not sure if @Rainesh has these firmwares (probably) So please don't pay for firmware or maps, if you can burn a CD and a DVD, you can have the files and DIY this at home (or buy a cheap enough external DVD-R)
Infotainment System Restarting endlessly
I have sent you the file, the instructions are on I believe Page 12 of this long thread. From what I can see, as long as you have a version above 1761, then you should be fine to apply. This contains many languages, they don't release 30+ language options, it's all baked into one single release.
AndroidAuto not working with S23Ultra
I have sent you the 1790 & 1798 firmware to try and load. Cannot guarantee you any success, but at this point you should try to see if you can apply what the dealer would load.
That portal has never shown a firmware update, despite them existing
There will be some forced updates, say an emissions recall that they MUST perform or at least in some types, give you a choice (if tuned for example) If you read the TPI document on the previous page (12?) and look at the section called "Customer complaints" and in theory if you state these to the service desk on your booking, and they should investigate. Sadly quality of dealerships vary, and sometimes you have to specidy a TPI document number to do their work for them (damn!)
Tyre Pressures provided are wrong
All questions are valid, I did see in the older image that there are two PR Codes listed for 2x suspensions. Then they removed this in new document 🤔 VAG are weird.
I can see differences in the pictures, so not sure why you don't. The profile of the tyres are not the same between the two documents, but I have not opened the file to look. I didn't produce the document, VAG did. Why they are different is a question for them.
Latest Infotainment version Bolero
Yes this can update to 0369 version, I will send you a link soon by Private Message
Software Update...?
It is not a Software Train, but I will use that to send you the files. EDIT: Did now see you have a VW Passat, I did wonder why the skin looked different, so I have asked you by Private Message for more information
Software Update...?
Can you please verify/post image of your current Software Train?
Yes of course
Software Update...?
Of course, apply at your own risk, but you should be fine. Best of luck with all your upgrades and recalls to be applied.
Glad it's confirmed. I do have 1790 you can try and load, but I don't think it cures the Samsung 23Ultra fault 🤔
Software Update...?
Yes they could potentially see the values, if they decide to look. So if you can download the files I sent, then you can decide if you wish to load them. Some have updated their systems themselves, and had NO issues with warranty.
MEN3_EU_SK370_P1185L MU 1760 I assume this is the firmware in you car, press and hold down your Menu/Setup button for 10 seconds to enter the Engineering menu, see if you can locate and verify above value. There's a potential update to 1790 if it can be applied...
Codes found, need to know what they are
I cannot tell you what exactly each code is for, but they are for licensing functions, like Navigation/Android Auto/Apple Carply etc...
Amundsen MIB2 Firmware Update
No hijack, this is a good place. Yes to 0369 version Sending you in next few minutes
My old 2015 car with MIB2 system works with AA via USB cable on S23 Ultra. Do you know firmware in this car?
Software Update...?
If you are on 0306, then you won't need anything special. You will update to 0308, then after it has settled down, apply 0324. I wouldn't sweat too much about the issue of it breaking down, and warranty troubles. The failure is very rare, and they have always had a red emergency menu, not actually even heard of issues loading the updates (apart from what was already mentioned)
Yes of course
Software Update...?
It's best to let us know what Software Train value you have, then answers to your questions can be given.
Firmware update 8755
Yes, I will send now, and you can banish the crackling Pork Scratchings bad mmkay
Faster than the dealers for sure, appointment weeks away... or in less than a few on a forum 😆
I will send you are link momentarily, and waiting on a dealer for appointment is not ideal. I guess they will eventually release by OTA, but that's a guess only.
Yes I can send you update from 0421 to 0490
