stu40
Members-
Posts
106 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by stu40
l have just done a oil air and fuel filter change and added injected cleaner as well.the garage had it running the guy said that it was still smoking after it had heated up really can’t take for a run as the mot has run out
hi every one looking for some help has anybody changed valve stem seal on a tdi before i have a 1.9 tdi with asv engine in it . car failed mot on emissions and other thing so i took it to a garage the guy said he thinks it could be something internally like valve seals or piston ring ant help would be appreciated
I know it might give you a idea what to look for
try this web site http://www.myturbodiesel.com/wiki/camshaft-timing-torsion-value-adjustment-on-vw-and-audi-pd-tdi-engines/ see if it helps
thanks for that yip I have dmf clutch the old fork was cracked and chipped as we'll so new bearing and fork everything feels ok now cheers stuart
just a wee update new release bearing and fork fitted job was not as hard as I thought it would be ,only a couple things I had to do before starting the job .i had to make my own engine brase I used cargo straps to hold the engine in place and to hold the gear box could not use my trolly jack to lift the gearbox up because my driveway has small stones on it,only other problem I had was when the gearbox was being pulled up it kept catching on where the wish bones connect to the subframe so after a bit heed scratching thought if I turn the box so the axle flanges where pointing up slide the box in then turn it to right that way the axle flanges are sitting above the subframe so all done clutch feels good cheers stuart
hi just been out check the release bearing fork going to have to get a new one just noticed it has cracks in it clutch seems ok so going to change just the bearing and fork see how it go's
so just been out to check the master and slave cylinder for leaks all clear as far as I can see,then went to check the release bearing and fork the cover of the bearing just came right off so could this be the problem any thoughts cheers
will have a look tomorrow you can see damage on the release bearing fork any way of checking the slave cylinder
wil have a look tomorrow there was a clicking noise when the clutch was not pressed in but a soon as you pressed it in the clicking would stop .also could not put in to gear with engine running had to start it in gear with clutch pressed in ,you just had to let clutch up about a inch and it would bit
I took the gear box out today the fork for the release bearing has damage at the top and bottom of it you can see it in the pictures and there is metal bits in the gear box housing have not check it yet .back a bit sore just now
do you think the release bearing fork is damaged been having difficult get it in to gear when engine is running can't get it to go in to revers or could it be the slave cylinder any help appreciated
hi all have just dropped gear box out to find the clutch cover missing some of the fork thing so do I go dmf or smf any help appreciated Stuart
morning all need a bit help yesterday push clutch pedal in and it felt just not right difficult to put in to first gear and can't put in to reverse when it's running and a clicking noise when the clutch is not depressed noise go's away when clutch is depressed could it be the clutch bearing any help appreciated stuart
Just a update on the cylinder head got it off gave it clean and there was some pitting on it so toke it to get skimmed to much welding needed on it so the guy offered me another one for £40 bucks will put up some pictures later Cheers Stuart
Help Needed, Clutch Pedal Failure
stu40 replied to Decender's topic in Skoda Octavia Mk I (1996-2004)
No just the pedal only one bolt have fun with spring -
Uses spark plug feller gauge think it works uses them my self to remove my radio
Garage down the road from me charges £25.00 to do a sniff test you can buy a kit but seen it priced at about £34.00 but it is still going through anti frezzes Stuart
And that's with out drink or drugs ha ha
Ok cheers for that Stuart
Where can I get the kit from cheers
It's got a new radiator ,water pump and thermostat all the sign say head gasket don't want to hydro lock it as it is a low mileage engine
sorry meant to mention that it is going through a lot of anti frezze daughter has to fill it up every day cheers stuart
sorry didn't know my last post would be put in general car chat, just with me having an Octavia didn't think, obviously brain not in skull haha, appreciated. stuart
