Stuart-h
Everything posted by Stuart-h
  1. Cheers. Would the dealership also stock them at all?
  2. Cheers. Might have to pester the local dealer !
  3. I have yeah.
  4. Any one got any idears on what the sensor does ? Its on the left front of thr car and mounted on the shock. Ive circled it in white.
  5. Its the columbus unit.
  6. Does any one know what the satnav runs off? is it a sd card or on cd at all? I cant figuar out which it uses!
  7. mines gone the same way. If i remember rightly think the pump is nackered!
  8. Cheers snapper.
  9. Is there an idiots guide on changeing the rear discs at all ? Ive found the mk3 guide on how to do it with out having to take off the caplier carrier and some how trying to remove thr welded in bolts! brake pad low warning light. Is there a simple way to replace the wireing loom at all ? got new pads and discs on the front but the warning light comes on. I know the pin is broken though.
  10. Is it possible to change the donut your self? Mine has sized as well. Can’t afford the stealership prices at the moment !
  11. Morning all. Found my self a space saver wheel. Tyre size T12570r16 wheel size 31/2J16 et25.5 h2 tyre size on car is 205/45r16 does any one know if thr space saver wheel will fit the car at all ?
  12. When i got one for the octivia if I remember correctly it cost bout £60 ish supply and fit with 4 new locking bolts and key.
  13. Have a look on www.blackcircles.com theyll have loads of different tyres depending on what your budget is. mail order or they get posted a local partisapting tyre dealer.
  14. Wheres thr best place to get pads and discs from Thats cheap ? im looking at replacing the discs and pads all round. Been getting quotes for bout £500 ish all round.
  15. Does any one know of any Skoda or vag group specialist’s in the Burnley area? Want to get some work done on the car but I’m not keen on paying dealer prices !
  16. Skoda uk suggests 210,000 km or 5 years. Not sure what Skoda australia suggests though.
  17. Ive got a westpflia on mine and thats a 4x4. Mind you it came with it already fitted!
  18. I can have a look !
  19. it a 1 liter 2001 model. As far as i'm aware the fuel lines havent been disturbed.
  20. The car is on a 2012 plate
  21. *not skoda related* Heres one for you lot. My father in law changed the cam belt on my other half's vw polo the other week. The now refuses to start at all. Engine turns over no problem. Back fires now and again but still doesent start! Water pump & cam belt have been changed along with new spark plugs, ht leads and a coil pack. Has any one got any idears or thoughts at all?
  22. does any one know the part numbers for an: Oil Filter Air filter The car is a 1.2 tsi petrol
  23. Gearbox specialists in Ayrshire and Scotland! Neil Engineering. Transmissions – Alpine Transmissions I dont know if the 2 garages are to far away from you
  24. I’ve been looking on the site for them but can’t find the link. Any one know if there still being sold ?
  25. Mines up at the dealership in Colne t the moment. They’ve come back with the prop shaft bush that has sized. might be same on your car.
