kentphil1
Everything posted by kentphil1
  1. You need to be cautious using too much radweld, as that can cause you other issues. It really is only meant as a stop gap solution, but it might give you a few more months of use perhaps longer if it actually can get into the hole and seal it. How much coolant do you think you may have had to top up since you put the radweld in?, just roughly to the nearest pint?. You could try running the car on the drive once its warm for 15-20 mins with the climatronic on max to let the radweld fully circulate into the heater rad. The thing is a tiny pin hole in the rad will produce a lot of steam once the system is warm, but may not need much radweld to seal it. Radweld needs to enter the leak area so that it can react with being in the open air as the car cools to seal the leak of fluid. It's a bit like toothpaste trying to squeeze out of a tube, while the cap is on it is nice and fluid, but leave the cap off overnight and it goes to a more solid lump on the end of the tube. That is a well over simplified way of explaining how rad sealers work, but hopefully you see where I'm coming from with it.
  2. If it is blowing thick mist, it does sound like a heater radiator, as that is just fine steam being sucked through the vents. I don't want to teach grandma how to suck eggs here, but on a normal car you have 2 radiators in the system. The first is the large cooling radiator which most people know lives at the front of the car and is fairly easily accessible. There is a second heater radiator which is about 1/8 size of the main rad, just for the purpose of providing heating which lives in the air distribution box that is located inside the car behind the dash. To get access to remove the box and then to allow removal of the radiator means almost a complete interior strip - i.e seats, dash, centre console and a fair bit more. This vid albeit on a lhd car shows what needs to be done, as regardless of which side the steering wheel is on, the basic job is the same. I had a neighbour who had a quote that was in the region of £900 fitted from a vw soecialist, the local main agent wouldn't even quote. the only way this gets cheap is to use your own labour, but it is a fairly big job and not for the faint hearted as the aircon deeds to depressurised and then regassed at the end. You can confirm if it is the radiator by trying the car with the temp set on cold, if it is slower to mist or does not mist then that is your issue, as the rad is out of the system when the temp is set to cold. I appreciate the current weather does not lend itself to driving without heat but you could run the car up to temp on your drive with the heater temp on cold and just see what happens. There is a tiny possiblity that your air con drain could be blocked, but if the test i detailed above yields no mist, it probably is not that. When you installed the Radweld, did you put the heater temp on maximum hot?, if not, it may not have found it's way to the heater rad yet. If you want more info please ask, hope it helps, Phil
  3. I would be inclined to get the car onto a cooling system pressure tester and see what that yields, including testing the radiator cap itself. You have done the obvious bypasses and diagnostics, time to dig a little deeper. One other thing, you mention that the fans cut in when they should, but are they runing at the low or high speeds?, as the fans have 2 operational speed modes.
  4. I have used that method for nearly 10 years, so can also vouch for it's effectiveness. I also use a Pingi on the dash if the weather is really cold and damp - also very effective. However, if it has the startings of a heater radiator issue, where they can leak tiny amounts overnight which are only really noticed as an odour for the first minute of the radiator warming rather than coolant loss and an oily deposit on the screen that takes 2 -3 days to build up, it will turn the screen to a fog like vision area once the warm fumes hit. This will only clear by wiping the screen, as the deposits are almost like steam, which will only get worse as the heater rad degades further. I 100% agree as to the effectiveness of getting rid of condensation, but I am just adding a word of caution if it is a heater rad, as I have been on the end of a failing unit and it's not nice to live with. This was why I was hoping the OP might have reposted, just to we could sort the wheat from the chaff (or the rad from the condensation ) Keep safe all, Phil.
  5. ^^ As above, drivers door master loom may have issues.
  6. If what I think may be the issue turns out to be fact, the gel approach may make things worse, but it is worth a try even if just to rule out condensation. Perhaps the OP could post his findings so we can assist them further.
  7. When you look through the translucent expansion tank with the engine running, do you see a regular flow of coolant running back to the tank if an assistant lifts the rpm to 1000 - 1200 ish?, or does it just sputter back or even no flow at all?. When was the water pump/cambelt last changed?.
  8. When the engine gets up to temperature, and you have the heater on, do you smell a slightly sweet smell for a minute or two until it settles down?, Is the deposit on the screen slightly oily/slippery to the touch?,
  9. If it is a Westfalia removable unit, the electrics should be on a drop down bracket that can swing down from behind the bumper cover. The pivot should be visible as it is bolted to the towbar beam, behind the bumper. If it hasn't been used in a while, the pivot may require a dose of WD40 on the pivot bolt to get it moving again. Hope it helps.
