VRs brake upgrades...a question
Still can't find anywhere that will supply DS2500 pads for a lowly 1.9tdi Amdiente
IIRC the 1.9 ambiente uses 288mm discs whereas the vRS has 312mm discs. I posted this on another thread recently;-
"Finished up talking to Tim @ Circuit Supplies UK Ltd 01525 385888 who is the UK importer for Ferodo Racing pads. After some discussion we reasoned that, as there was commonality between the Golf V and Octavia II, Ferodo Racing's DS2500 Part No; FCP1641H ought to fit the 288/312mm discs on the Octy. RRP with VAT and P&P is £124.48 (the DS2500s have always been more expensive than EBC pads)."
You can also buy the Ferodos from Demon Tweeks Motorsport, Motorcycle, Modifying, Parts and Accessories as this is where I got mine from; perhaps better to call them than rely on their website.
The alternative is EBC Redstuff Ceramic V3 brake pads - Part No DP31517C; available from Larkspeed or Demon Tweeks.
whats the upgrade route for vRS brakes then? think im going to try some better pads first but i can get the standard pads to fade far to easily, which isn't nice when your flying towards a corner and the only thing slowing you down is engine braking
Ferodo DS 2500s work really well, they certainly do NOT fade; see post above for part no.
hmm, if I upgraded to R32 brakes on the front would i be able to get some diffrent caliper carriers and put my exisiting vRS brakes on the rear and get a double whammy upgrade?
How is the handbrake going to work?
So what we need to confirm is what type of brakes ar fitted to the OP's Octavia 1.9. I was under the impression they were FSIII brakes and not ATE.
@Octygone - See told you you would go for 312mm fronts :rofl::D:thumbup::rofl:
The pads in the 288mm and 312mm callipers (both ATE) are the same.
If the 1.9 has the 280mm FS III callipers you will struggle to get performance pads for it. If it is this set up have a look for pads for a MK I Elegance 110TDI as it had these pads and there were a few upgraded pads around.
You can get the EBC red for it, but while i think they are great it does seem a fair few on here hate them. I'm still good after 10k on them though :confused:
If you wanted to get the items sibart took of his car you would need new hubs but otherwise that is it.
If you are running on 288mm brakes (ATE) I have the pads that came out of mine when I went up to 312mm that you are more than welcome to (assuming yours are not OEM) as mine are.
I have to say I really didn't think the 288mm was up to stopping the Octy II as I had some major ARRGGHHH NOT STOPPING moments including the sensation of teflon brakes you describe.
Stopping fine then suddenly you're not any more and on teflon.
I got the brake fluid changed (car was 18 months old) and it was fine again for a while. When is started being a bit silly again I got some bigger brakes.
Worth mentioning the tyres too as cr*p tyres won't help.
Bahnstormer has linked to my 312mm thread with the info on, but I'll confirm the 312mm is a massive improvement over the normal 288 discs :)
EDIT, just checked, if you were willing to try EBC they do OEM grade, green (I would avoid these) and red in both the 280mm FS III or the 288/312mm ATE calliper fittings.
who needs a handbrake anyway :P
decided im going to upgrade to ebc red stuff v3 ceramics after taking a mates gti mk5 out with some, the diffrence is awesome!
any one know where i can get a set of the pads at a decent price?
thanks again
Dan
I like the EBC reds, but some people on here (many) hate them.
I got mine from Larkspeed.
The part number is available on the 312mm octy II conversion thread of mine that bahnstormer linked to above.
What I will say is that if you are going to do lots of track rather than fast road use I'd either go for the Yellow or DS2500.
People on here who have tracked the things quite hard really don't like them.
On the road, with some quite heavy use on OEM discs they have worked very well for me.
I'm also thinking about going for the EBC Red stuff, when my 1st set of OEM pads get replaced at the next service. Are these doofers definately a bit better than the OEM pads, and are the OEM discs not going to dissolve under them?
Also, is it normally just a pair of fronts that you would replace first, and leave the OEMs on the rear, or is it advised to replace the pads all round to the same make?
Next, are replacement, road legal brake pads considered a mod, if the rest of the brake setup remains the same and you just replace like for 'like' (as it's just a set of consumeables) when one set wears out?
Oh yeah, and how much would a set of OEM skoda pads costs vs. redstuff?
Sorry for hijacking thread with some more questions :)
They OEM discs won't fall apart as the reds are not hard on the discs and don't dust up IMHO. Also I think they are much better than OEM and they have the same 0.5 friction co-efficient that the DS2500. Some people on here seem to say they break up, but I personally have not seen this on mine. I will say I think they are definitely a fast road pad not a regular track pad.
I have put better pads in the front only. What you must not do is put much better pads in the rear and less good pads up front IMHO.
I declared to my insurance but it cost zero. I would personally check with yours that after market pads are ok ;) sure they will be as the reds are E marked IIRC.
OEM equivalents from GSF etc - about £35
EBC reds from - about £60
OEM from dealer - about £85
These are averages.
When you upgrade the brakes on a Vrs, what size discs come off (the standard ones) as I am looking to upgrade my 1.9tdi ambiente brakes ....any ideas ?
Can you take a picture of the front calipers, through the wheels should be fine.
Here's a pic of an OEM front disc on a vRS (312mm) with OEM caliper and 18" B14 wheel;-
Hope that helps.
PS> I've got a pic of the same with some 17" rims, at home that I'll try and upload tonight.
Not really we are after the front brakes of a 1.9 ambient, to see what type of caliper they use.
Not really we are after the front brakes of a 1.9 ambient, to see what type of calliper they use.
Oops, sorry; too early in the morning; brain not fully engaged yet!
You were of course addressing the question to Octygone.
Yep hence me quoting him ;)
Early? I've been up since 5am, Evie doesnt like to lie in so none of us can :(
