noise?
hi all :) been a while since i have posted on here but couldnt resist while i have been driving my felly with the window down i have noticed a brief high pitched "sqeeek" as i iether accelerate or take my foot off the accelerator it seems as if it makes the noise when the engine "rocks" also did they do fellys with leather interior as i would like mine to have it :):P any help i would be most greatfull for :) thanks tom :thumbup:
Yes the Laurin and Klement special editions came with heated leather seats but I think your chance of getting any is quite low unfortunately,
a squeak? Like a loose belt?
Mines knocking when i change gear but i have a bottom mount ready to go on next week so that should cure it.
probably worn rear engine mounting
I have a "Knock" in similar circumstances when the engine shifts... again think it must be the engine mount worn.
And you definately can get a leather interior for the felicia as mine has one!
If you wanted something more funky the yellow lather out of the fun is also an option!
Phil
The lower stab bar on the engine gets weak. I found some petrol pipe inserted into the voids of the bush worked a treat.
looks like i will need to find a donar laurin & klemnt felicia then :( dont spose anybody knows of any ? i have seen one in linconshire for £250 but it isnt taxed or tested and seems to much chew to get it up here to get the interior to scrap it :/ although i would travel to get the interior :)
thats a perfect example of how not to advertise on ebay!!:P
LOL - not the best, could have put some pics up!
Guess that's why it only got bid up to £120 and reserve not met. Wonder what the reserve is and what condition it is in :)
Philje is your Felly still clunking?
I got the mount for mine, hopefully should stop mine making those knocking noises.
Yes she's still clunking... let me know when you've got it fitted and if it improves things at all... Just hoping she holds out for our drive to germany!!
It's fitted and it has made a bit of a difference.
It still knocks but only if I let the car jolt sharply by idling in 1st/2nd then just prodding the accelerator sharply (in a quiet corner of carpark or quiet street is best for this)
*Actually difference is very minor, it prob wasnt that mount as it still intermittently knocks as I found out today on a drive back from Halfrauds.
The search continues :confused:
