Fun Bus Engine
Hi, Can anyone tell me which VW my Fun Bus engine is out of? Ive just bought one with a blown engine and I am getting now ware fast trying to source an engine. It is the 1.6 multipoint injection and is a AEE engine code apparently...
Any Ideas....?
Thanks Matt
:)VW Polo or Golf.
Aparently they are different engines on the same code....! The polo has the starter on the front and the golf on the back...
Im not near the car at the moment so cant see it..
The aee engine in the skoda uses magneti marelli electrics and the dubs use bosch, so if you get an engine out of a dub you will have to change the electrics over
where abouts are you? cos a scrappy in scunthorpe have a felly 1.6 in, with lowish miles
Wakefield area... near leeds. Im taking the head of tonight to see whats happening. Think the valves are bent. But i have a spare head so depends how much damage is on the pistons... Do you have the number of the scrap yard... ive had a quote of £250 delivered for a bear engine.
And does any one know what size multi spline socket the VW head bolts are?
You could try Overton Service Station in Ludlow - they have quite a few old cars for scrap lying around (though in Shropshire which is quite away from you).
it makes no difference, you would use the skoda gearbox on it anyway using the adaptor plate which will be on your existing engine...
dont worry yourself too much about the electrics either, just use the stuff off your existing engine, all of the sensors are the same anyway, it's just the loom that is different.
the right hand engine mounting bracket and timing belt covers are slightly different too but your can swap these from your existing engine too:)
so any aee lump will do
True the electrics shouldnt be a problem but some of the sensors mount differently so you would have to swop over a few bits
R.C.Edley motor dismantlers 01724280915
Give me a call if you need any help, if they still have it, I know scunny well and i live in donny. Ive also got a trailer that would carry it. PM sent with my number
M10
