xenon fault code skoda octy 2
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
Shop #: WSC 73430 790 00000
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation
how do i set this? its never come up before
looks like ive solved it now (its not re appeared anyway).
Carry out the basic setting.
is that the one where i click on 1 and then the on/off button then save it ? if so ive done that along with the one where you click once for lower the beam once to up it and once to put it back to normal too. done re scans and it seems to have gone.
VW Touran (1T) Headlight Aim Control (Xenon) - Ross-Tech Wiki
Headlight Adjustment
[select]
[55 - Xenon Range]
[basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
[Close Controller, Go Back - 06]
Ignore the part with the adjusting screws.
thats the one stu, i found that on the golf 4 or 5 as i couldnt find it on the skoda bit and knew they were both the same. cheers again.
