Removing the MAF sensor
Sorry to be stupid here, but how do you remove the sensor (to try cage mod)? Does it just pull off or is there a clip?
Hi
There is a multiplug on the MAF sensor.You need to push in the small clip on the side and pull the connector block off.You don,t need to remove MAF sensor.Hope this helps:thumbup:
