Ipaq keeps on Hard resetting itself
Hidy Peeps
Recently bought a new HP Ipaq 2210 and it keeps resetting itself, it will work fine for a couple of days but then you will turn it on and the Bluetooth light and the charge light both come on together, then you find that it has done a hard reset, battery power is nearly always full, so has anyone got any ideas?
Cheers George
I only opened this 'cos I read it as "Iraq" and thought "eh? What the **** does that mean?" :P
Iraq keeps resetting itself? That would explain a lot............ :confused: :twirl: :rolleyes2 :crazy: :dizzy: :bigshock:
Phil
Havent come across that problem with my 2210. Battery lasts for ages when switched off. All I can suggest is opening the battery cover and checking that the battery is seated correctly and not loose.
Think it may have to go back, because even if the battery was loose it shouldn't lose my programs because the back up battery is still on 100%
