Weak blower
Hi, I have a 1998 Felicia 1.9d. I think the airflow from the blower is very weak. The blower motor works and it sounds loader when you increase the level from 1,2 and 3.
But, I don't think the airflow increases more than perhaps very very little when you go from 1 to 2 and to 3 (but the sound increases a lot).
Do you think you have ok airflow in your Felicias? I'm not sure if this is model specific or if it is a fault and I should start searching for faulty blower channel flaps or faulty mounted blower motor and so on...
I think the airflow in my Felicia is MUCH weaker than in other cars I've driven, but I havn't compared with another Felicia...
BR Pag
It must be a problem with your car as i find the blower strong, you will find there isn't much airflow through the vents either side nearest the doors though.
You might have something that obstruct the air-flow, or maybe just spray some WD40 on the rotor of the motor to reduce the noise...
Is there a pollen filter that could be choked up absolute solid if it's been in since new?
Solved!
The blower motor was mounted so it rotated the wrong way. I turned it around and now it's working ok. A previous owner must have mounted it the wrong way...
Thanks for the help!
Pag
:orb_clap:
To you for working it out, and to the previous owner for the sort of natural stupidity that no amount of training could ever hope to reproduce!
