MPG Computer Reading
Is the average MPG reading stored in the computer or are the readings lost when you switch the ignition off?
There are two figures shown.
( / ) 1 will reset to zero if the ignition is off for two hours (or you manually reset it yourself)
( / ) 2 doesn't automatically reset - I believe it will keep going for up to 9999 miles but I've never left it alone that long as I always use trip 2 to measure economy on a tank full
2nd one resets it's self every 100th hour...
unless you choose to reset it yourself before hand.
Have to refute that my 2 has nevr changed and I have had the car 8 weeks now and it shows mileage total since I drove away from the garage. Or have I missed something as usual.
Is that for a Fabia 2 or 3 because mines definately goes back to zero after switching off the ignition for more than 2 hours?
960
960
That is the same for both, as you are using memory 1.
If you press the bottom on the bottom of the right hand stalk it will change between memory 1 and 2.
Thanks mdk1, I will try it next time.
Tried it last night and it works. Thanks.
