Wheels for Fab 1.4
Afternoon all
Im wanting a set of wheels to put on my fabia 1.4 and was wondering if anyone knows which size alloys will slot straight on with no probs?
open to suggestions??
p.s probably goin to be 30mm lower as well! :thumbup:
Check on the for sale section, Dunkx has a set of 16inch vRS alloys for sale off his Furby... Oh with good tyres as well...
17 inch will fit but your suspension might struggle to cope...
cheers
Dazz
Hi there
Ive got 16" with 30mm lower on my 1.4 classic :) No problems and handles well!
Andy
cheers mate, sounds good.
How much did the disc upgrades set you back for your classic?
Hi there
Andy
17's will fit no problems
The numbers you need are 5 x 100 which is the stud pattern. Somewhere ET35 offset will be fine and fill the arches nicely without rubbing. You will need 205/40 17 tyres which are very common and can be had for around
looks like i will be settling for 16"s!!
could anyone suggest the size of tyre that will be best for them, considering they are goin on my fabia 1.4
cheers
Lee
That will be 205-45-16
thats the standard wheel size on the furby vRS
are the arches around the wheel on the fabia 1.4 the same as the vrs? and i am also dropping it 30mm, in case that affects things??
