No Rear Washer
Hi Guys,
I've had a look through the forum and cant seem to find a specific answer to this .... except it might be a split / off pipe....
Rear wash wipe seems to be working - except there's no water. any hints as to where i should be looking for pipe joints etc ?
cheers in advance :D
If you use the "Search" button you will find detailed advice on here.
Yep, i'd wager behind the n/s/r boot carpet, pipe is probably filling up your electrics nicely.
thanks ... i have designed, built and run several forums so i'm familiar with the search function :)
cheers guys - i'll have a look when it stops raining :(
hang on ... i just went to have a look and couldn't see any washer jets - is it possible my classic just doesn't have them ?
if so ... DUH SH*TE BU**ER - in that order!
Had same prob,told by mechanics at my local dealer using other than Skoda screenwash will cause problems;the hose disconnects at some point!Apparently a directive out on this.
Sorted at first service.
Go figure.:confused:
well i found the washers - on the top of the wiper spindle - but i've never refilled it since buying the car from Abrahams Skoda and the fronts work fine - so i'm guessing it was off from then - i'll try to clean the jets and see if they kick up but failing that i'm going to have to start stripping down the carpets and rear hatch trim :(
Lummox - i had a look in through the bulb access hatch in the rear carpet but couldn't see any tubing --- lower or higher ?
you'll have to pull back the carpet fully to get into it.. Its just above the inner wheel arch:) If its off put a couple of dots of super glue on the joint, the have a habbit of popping off;)
