Intercooler
Anyone know if the S3 intercooler would fit a Octavia Scout 2.0 TDi?
Physically I think yes but you will have to do some research on the pipework.
OK the scout has a 1k0 415 803 f which has one high and one low inlet so different to the s3 intercooler.
But does any one know if the 1k0 415 803 a intercooler is used on a 1.9 tdi, altea maybe? as that might give me the pipes i would require.
Are you sure it has 1 low and 1 high, the diagram for sure doesn't show it that way. Did you look at the radiator by accident?
No, wish I had. :-(
The Scout has a 2.0 8v TDi. The inlet is at the back, so i think that it must be a similar intercooler to the 1.9 tdi's?
Pity then eh.
Funny how the Scout uses a 2.0 8v, whats the engine code?
engine code is bmm. I think d 8 value might b to do wiv d dpf.
But i did find that d old 150pd intercooler looks very similar so maybe i could use some pipes from one of thoses? The research goes on....
I know these drawings aren't always perfect but have a look at the attached image.
22798.attach
umm d picture is incorrect as it shows d turbo outlet on d wrong side. Although this does show that there maybe some pipes that i could use.
I can understand d turbo - Diesel Turbo but what is d picture, surely not Diesel Picture. Oh no wait it's your bad speaking!!
:rolleyes:
Come again?! :eek:
oh my... Its like being back at school.... In my defence i was using my mobile, so i was in text mode....
Anyhow for those more senior in years d=the.
Hope that helps.... :-)
Much better, and easy on the senior years :rofl:
