*Urgent* Fabia dashpod been unplugged...help :)
Friend of mine has unplugged his instrument cluster and having done a auto scan - the following log was generated...
VAG-COM Version: Release 311.2-N
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 LA
Component: 1,9l R4 EDC 0000SG 5405
Coding: 00102
Shop #: WSC 13765
TMBWU46Y644030802 SKZ7Z0D2329722
3 Faults Found:
19586 - EGR System Regulation Range Exceeded
P3130 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V40
Coding: 00188
Shop #: WSC 13765
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
Address 08 -------------------------------------------------------
Controller: 6Y0 820 045
Component: Klimaanlage X0830
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
79-00 - Please Check Fault Codes
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25738
Shop #: WSC 13765
1 Fault Found:
Skipping Address 15-Airbags
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0037 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
1 Fault Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 13765
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 33 Komfortgerát 0002
Coding: 00066
Shop #: WSC 13765
1 Fault Found:
01312 - Powertrain Data Bus
End -------------------------------------------------------
How do I fix his car please :)
Thanks.
i'd say tou need to double check that it was plugged back in, and it it was, then i'd look at the wires
Those plugs are a little fiddly. If the codes don't clear then check it is properly plugged in and it should clear ok.
He read this and sorted himself cheers guys - it was the wiring.
Now his key won't lock his car remotely, although it will start it. Any ideas?
if he has the second key shouldn't be a problem -
Fabia-vrs.com - Key Coding
Follow the bit about coding fobs.
Thanks Stu :thumbup:
