Runing rich & lean
So using my funky new cable and VAG-COM..........
17356 (P1128-35-10) Bank 1 Mix too Lean (Mult)
16556 (P0172-35-00) Bank 1 Mix too Rich (Mult)
VAG-COM "Readiness" Scan shows everything a.ok apart from "Oxygen Sensor" which is "Failed or Incomplete" and Catalytic Converter, which comes up the same. Depending on how long the engine has been running, Evaporative Emissions also has a bit of an occasional dicky fit. Doug & Me have done the whole injector cleaner routine, I'm going to clean the MAF in the next three weeks, but anyone else think it's probably a good idea to swap out before it goes totally?
Or could it be something else? (not likely, but here's to hoping it's cheaper than a MAF........also not likely :P )
  • 4 months later...
Ok, im not asking a silly question here but have you changed the bank one lambda probe because as a working master tech in a skoda dealership, i know for a fact that 99 times out off 100 this is the cure
Really :holmes: ?
Dont think you were in my group and we are the first ones to pass Skoda Masters.
Unless you were from another brand and transfered?
Do tell fellow M/T.
Oh and theres a whole diag routine with the altitude sensor on the 2.0 petrol engine that needs to be followed for that fault. Most of the time it ends up being a fault with the MAF, but there have been some faults with the sensor in the engine ECU, so try the MAF and if it needs further work it might well be a dealer visit im afraid.
Exchange MAF's are availble now for around
Talk about raising the dead.............
I bought a new OEM part from Euro Car Parts (significantly cheaper than the price the dealer quoted) and fitted myself in 15 mins.
Old MAF removed, washed thoroughly with IPA. Now in storage for future use..........lol.
Thanks anyway. Seems a shame that just as I've put the Octy up for sale, you're reaching new hieghts of potential unsefulness, Ross......Damn!!
He He He, glad I was right though ;)
Wouldn't have been a resounding endorsement if you;d been wrong, especially after such a recent acheivement........ ;)
  • 5 months later...
i aiso have the some problems on my 2001 2.0l octy code 16556
