Power inverter in Octy
photo#5232859140561097410
Thought I'd mention it here - my local Sainsburys (Cheltenham) are knocking out the Ring power inverters at half price at the moment (£15)
It's can shaped and that, compared with the length of lead, makes them a perfect fit in the Octavia.
They look right handy, perfect fit.
I'm off to the Sainsbury's site to have a butchers. :thumbup:
Not shown online.:thumbdwn:
If I need a bunch of bananas, this is the place.:(
Another scearch reveils £37.99 from a shop in North London!
Edited by Wayne Kerr
What wattage are they rated for? I have a maplin unit that comes with both a fag lighter plug and crock-clip leads for a direct battery connection. I found that running mine in the from the boot fag socket that it struggled a bit more - guess the current demands with a bit higher than the guage of cable used to supply the boot.
150W, it's got a USB socket as well.
Looks to be a bit of a bugger if you need to use the arm rest.
I've got one from Argos mounted in the boot;
Runs off the power socket in the boot at the moment but intend to run some cables direct to the battery soon.
