Fault Code P0118
Hi,
ive got a fault code P0118 - Engien Coolant Temp High Input.
Should this be cured by simply replacing the temp sensor?
As long as you are sure that it isn't high then it would certainly be worth replacing it as it's a common failure.
Hi,
Cheers for the reply, yeh im pretty sure it isnt high as the fsult codes been on the car for about a 9 months and as yet doesnt seem to have caused any major problems.
Any idea on the part number and where I can get it from?
Main dealer will be a good bet. Not expensive.
