Cat vision
Not everything you read on forums is fact..........some stealers are pretty good but it all depends on where you go I guess, good luck.........:D
Wait a second, so that means it's true you and Wardy are having an affair?
:eek::eek::eek::eek:
:rolleyes:
:rofl: - that's how rumours start!
Oh wait, hang on a minute.....
:D
So it would appear that you can get them in black (or is it called onyx?). However, I need on without the sunroof switch, so I'm looking for one like below, but in black:
So, can any owner confirm that they have such an item, and does anyone know a part number?
Ooooooh
Look what I just found (in this forum)
It would appear the part number is:
3U0947105 for 2EN Innenleuchte in perlgrau Interior lamp in pearl grey
3U0947105 4D5 für die 3U0947105 for the 4D5 Innenleuchte in ivory Interior lamp in Ivory
3U0687596 Einbaurahmen? 3U0687596 mounting frame?
[EDIT]: Bugger, and I've just realised neither of those are dark :(
Edited by sdenny
  • 2 months later...
:bump:
I'm back on the trail of this again! So, does anyone kindly have the part number for the black/onyx Superb Catvision light with sunroof dial? Like the one at the start of this thread...
Or if someone could do some ETKA digging for me?
Cheers,
Steve
:bump:
I'd love to help, but i gave up :(
I'll persevere, but I'm stopping short of a general call to a Skoda Parts dept at the moment! Think that might be a step to far, to probably have to explain what I'm thinking of doing!
Steve
Well i've just been pointed in the direction of this thread...... I'm another who's wanting one of these in onyx but without the sunroof gubbins.
Might have a wander down to my local stealers parts dept to see what they can find on the system..... Were these only fitted on certain spec Superbs or on all of them?
Dave.
I think it's on all models - but not absolutely sure. I know it's on Elegance as i have one.
John
I'm not sure either Dave, but would certainly go for it being on all Elegances as well.
Be interested to know how you get on, obviously :) Especially if they can source one and you can offer it upto the vRS headlining, to see if it's an acceptable match...
There's also some more info, possibly useful, on a thread I started in The Skoda Shop section:
http://briskoda.net/skoda-shop/superb-catvision-front-interior-light-sunroof-model-onyx/128594/
Steve
Partnumber for interior light without sunroof in 'pearl grey' is 3U0 947 105 2EN.
I think the above post has nailed it, but to confirm - yes they're fitted to all Superbs. It's a standard feature.
But don't forget that is for pearl grey not onyx/black.
Steve
Well i went in to Bickertons today as their parts guys are usually pretty good and i think they like a challenge. :D As noted above they only come in the cream and grey..... From the info we could find it looks like they were indeed standard on all Superbs. They also use 4 W5W bulbs rather than festoon bulbs.
The parts guy even found out an old Superb brochure so we could try and see how dark/light the grey one is but you couldn't really tell from the pictures in the brochure. He also even went checking that they didn't have a superb in stock or in for a service to check etc....
Now the bad news for you Steve....... The one with the sunroof controls is £78 with the other one being £48.
It does look though like it will be a case of spraying the unit into an onyx shade.
Dave.
Edited by WaveyDavey
:eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
Thanks for the info Dave. I was actually already prepared for the price, as David quoted a similar price in my Skoda Shop thread :(
Quite a bit of money for a light :rofl:
Dilemma is the Passat W8 sunroof model is around £50, and the only reason I was looking at the Skoda version is because it would avoid spraying it. So probably not going to go down that route now.
Does still leave the problem of the actual spraying though, and how not to coat the illuminated details as if they're covered in black the buttons etc won't be illuminated :rubchin:
Steve
Steve
I'm still liking the Superb one so as to keep the green buttons.
The first and only couple of things that spring to mind regarding spraying would be to spray the complete unit then very carefully scratch off the paint over the symbols that you want the light to come through....... If that makes sense??? Maybe do this after each coat. Or just as fiddly the obvious masking tape cut to perfectly cover the symbols...... Either way would seem to be a pain. :rolleyes:
Dave.
Dave.
Humbrol (model paints) do a paint on mask which rubs off after use.
Oooh, interesting :rubchin:
Any more details? I have a model shop nearby....
Steve
The buttons are illuminated with normal 3mm leds. They are dead easy to replace to green leds.
I've done that to my Passat W8 light bought from eBay.
:bump:
Cheers,
Steve
Shush....you'll wake Roto up again :rofl::thumbup:
Black insulation tape from Wilkinson's - about 25p.
rotodiesel - now awake.
There!!! waddeye tell ya, LEDS all over the world are in hiding fearing the black tape treatment.
I've already offered to swap him for a standard interior light! :)
Steve
