Unpart Brake Pads
got a set of cheap front brake pads from local motor factor for my 2004 Fabia VRS 1.9 diesel , and even though I gave disk diameter ( 288mm ) and all the vehicle details etc , the information on the box doesn't show the VRS model.
Before I go and take the wheels off ,does anybody have a Unipart catalogue to cross reference this ( couldn't see anything of Google ! )
thanks !
24018.attach
2.0 has the same front brakes as the vRS so looks good.
Hi,
Thats the right pads for your car. There are two different sets available, all be it they are the same pad. One set has wear indicators fitted, the others dont.
Having worked in a motor factors for a number of years we always had customers asking about the correct application because the label on the back did not specify there exact car. So your right to ask before you go and strip the brakes down.
HTH
ok thanks , and if it ever stops raining I`ll go out and change them !
