radiator fan
i just noticed that my radiator fan work as "fluctuation"
it's speed get changed from
less than normal ........................to seems to be turning off:(
shall i replace it ?:confused:
if i did with std one or can i upgade it with one bigger?
all posts will be appreciated
You're saying that your radiator fan speed isn't constant yes? Isn't that a good thing, as long as the water temperature is constant once the car's fully warmed up?
no, not good thing that i am from egypt & radiator fan almost turned on forever.
plus
the water temp is heated to operating temp & keep became higher (under red zone ofcourse )
what can i do ?
When were the engine and radiator last flushed, and the "anti-freeze" replaced?
I know freezing temperatures aren't likely to be a problem in Egypt as a rule, but the "anti-freeze" also contains corrosion inhibiters and acts as a "water wetter", which increases the heat capacity and heat conductivity of the cooling system.
