drop links, easy DIY job?
Hello.
My car failed mot on these both sides ( i knew one would it been clunking a bit for a week or so now )
They look pretty straightforward to change. Looks like all I need is the car up, the wheels off for access and a couple of nuts off and that's it.
Am I right?
and where is a good place to get the parts from, do GSF or ECP do 'em? Skod dealer quoted £19 + VAT each - :rofl: having a laugh
cheers
That's not that bad. Doing the job takes 20mins a side, the hardest thing being taking the wheel off.
Mine had this problem on the front right, had dealer telling me that my steering column had gone (£600) causing the knocking noise, my brother suggested the DL and it was fixed with an £8 part... bonza
Really easy to do. Should lift up both sides at the same time, so the links are at the same tension IIRC. Get new self-locking nuts at the same time for a perfect job....
HTH
Bas
cheers all, very helpful indeed. looks like I should save mi'sen a few quid then
