The Diesel Fuel Cooler
Fitted this kit to my car. Hard to tell if it's made any real difference but it's good to know the fuel is being cooled efficiently even more. :thumbup: My IC is also situated behind the grille which gives it good cooling. :cool:
IIRC if the fuel temp exceeds 80 deg C, the fuelling is adjusted downwards by the ECU. One person claimed that he regularly saw over 90 deg C in summer, somewhere UK or US.
Jase - any pics to show how you mounted the cooler?
Bas
Yeah - will try to get some tonight. :) It took some serious mongrelling of the underside of the plastic panel around the radiator to create a level surface for it to attach to. :)
Well, this is where my fuel cooler is installed. Convenient little cubby hole there, yet very well vented behind the grille. :cool: PS: Sorry for fuzzy shot. Battery died shortly after so I couldn't even take another one. :o
  • 5 months later...
Basil, did you end up fitting this to yours? The difference in your case would have been larger I would have thought
