Just gone onto the Skoda website to build my own car and I can add the following options at £0.
1.Heated front seats (£0)
2.Navigation system with dynamic module "COLUMBUS" 2 DIN, TV tuner, "MAXI DOT" (£0)
3.Outer and inner mirrors either automatically dimming, outer mirrors el. adujstable, heated, el. foldable (£0)
4. Electric adjustable driver and passenger seat (driver with memory, passenger w/o memory and w/o storage box under passenger seat) (£0)
It seems you cannot choose both (3) and (4). Does anybody think this is a right or is this a mistake
Were you trying to spec these on an Elegance for which they are standard equipment?
I'm assuming you mean the configuration on the Skoda UK website.
Right now, it's down, so I can't check out what you've found.
It does sound wrong to me, as the Elegance comes with both of these options as standard. One compliments the other, as you can't have memory mirrors with memory seats.
Perhaps it's down because Skoda are fixing this.
Bagpuss.
It was on a SE spec.
When you goto the section to build your own - you go through models/colour etc and then there is optional equipment.
The options I listed are £0.
Okay. I'm guessing that you weren't doing this on the Skoda UK website, as the options you've mentioned just don't make sense. If you were, then Skoda UK have made a c*ck up.
For starters, the Columbus you've mentioned lists a TV tuner. This isn't available on UK cars at the moment.
Secondly, the only way to get electrically adjustable seats is on an Elegance (where they are zero cost). You can't specify them on any other models.
Thirdly, auto dimming mirrors are also only available on the Elegance. The mirrors on the SE are electrically foldable, but they don't have either the auto dimming or memory function.
As for your original question, 3 and 4 can come together, but only as part of the standard Elegance trim level.
This may be different in countries other than the UK.
It was Skoda UK site - build your own car!!
Clearly a mistake then....
Probably explains why the site is currently unavailable.....for technical reasons.
More like, because all the options and prices were wrong.
