Brake Upgrade
Hope someone can help me with this. Time to upgrade the brakes on my Fabia vRS, and was wondering if you could fit the current calipers on the front just upgrade the carriers to 312mm ones off a Anniversary Golf or 225TT. And obviously put 312mm discs on, as the pads for 288mm and 312mm are the same, so does this mean the calipers aswell? So all I would need for a 312mm conversion would be: 312mm carriers, discs and new pads?!
Thanks for your help guys, Keez
if your brakes are currently standard you will need a full kit. ie. calipers, carriers, disc's, pads.
The fabia vrs uses different calipers to the rest of the 288mm and 312mm brake setups.
Yep he is right new calipers, carriers, discs and pads im affraid in all cost me bout £300 but worth it :)
