Help with Websense "web filter"
Help, this thing is driving me mad right now.
Trying to install Version 7 of websense security/web filter with reporting at the moment, integrating into an MS ISA 2000 proxy running in cache mode.
Now, I can get the software to install and run but have issues with the integration. I have tried several times now, basically the plugin gets added to the ISA console but the ISAPI filter is not installed, I cannot find websense-isa.dll anywhere on the server that ISA/websense are installed on so filtering is not working.
I did attempt uprading from V6.3 initially but it kept failing, so went for a complete uninstall of that and install of V7 from scratch.
Got it sorted in the end, in a roundabout way.
Following the advice on the websense forum, I uninstalled the web filter, then installed it again. Whislt the installer is running, grab the files from the installer temp folder, and manually copy them into the isa server folder manually once the installer has finished and failed to do the job itself. All working nicely now.
