18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
what is this code?
what is terminal 30? where is it?
any help much appreciated. thanks
oops repeat post
have you had your battery off recently? I think this code usually pops up when its been disconnected.
Seeing as you have moved the battery from the engine compartment to the boot, it could be a voltage drop due to the extra length of the cables?
it happens every time you disconnect the battery
Clear it off and see if it returns.
It is normally caused by the battery being disconnected as everyone says.
havent had the cables off in a while. dont know then.
its been cleared. i shall await further events.
thanks
