No access to menu in Maxidot
I have had this problem for a while now.
To rule out some sources i have uninstalled my Columbus navi, Blutooth phone and installed the org. Stream radio
I have disconnected the batteri for half an hour but still no menu.
My maxidot isn't orginal but installed by the local Skoda dealer
I get these two errors with my vag-com:
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Coding: 3D3F4F40072302
Shop #: WSC 30058
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 219
Mileage: 22581 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:56
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 22581 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:59
Any one has a good idea how to fix this?
Henrik, Denmark
Edited by mrbrunodk
Add notification
Does your stream radio works now?
Maybe an issue with the dashpod connectivity, especially as its been fitted afterwards. If you can try removing the dashpod and removing the connections and putting them back again.
I have tried to remove the dashboard but i can't find out how to remove it ?
It seems totally locked in place even after i remove the two torx in the buttom.
Is there a trick to remove it ?
If i manage to remove it will the car be able to start again ?
Isoma: Yes my Stream works fine.
I'm near giving up and going to let another Skoda dealer have a try.
Henrik
Edited by mrbrunodk
There are 2 clips on the top of the pod that need to be released after removing the screws. They are vetically mounted, so you need to run a trim removal tool or a ruler along the top of the pod to release them.
I would say you have a break in the CAN wires on the back of the radio or where you connected the BT kit.
If i had a break would everything else work.
Navi and phone info in Maxidot works !
How can i test if there is a break in the can wires ?
Henrik
The CAN Infotainment is what you should have connected your phone to so I'm guessing that is a good place to start.
Could i just disconnect the BT phone and the Columbus ?
I had the car at the Skoda dealer yesterday and they couldn't go into the Columbus the vag-com says: No Access: No power on kl 30
Can't understand it. kl 30 is the permanet positive and the navi was on ?
Henrik
It's probably because of the fault in the CAN Infotainment that the car 'cannot see' the Nav and assumes it's not working.
Hi Henrik, If you still want to take out the dashboard, let me know, I have tried it a couple of times, I´m living in Roskilde
John
Try 17 - Instruments > Adaptation - 10 > Channel 000 > Save
