caliper bolts
i'm changing my front discs and pads next week i got some new pads from gsf but there are no bolts with them like i got when i changed the rear's
i got those pads from skoda,do i need new ones for the front? if so where can i get just the bolts from
cheers
Different type of brakes ont he front, nothing to change.
many thanks mate !!!
might need a 7mm (iirc) allen key on a socket drive though (is the case for the FS III calipers), and maybe an impact driver to get the holding grub screw out (or drill it out - like what I had to do on one side)
You need an allen key not sure if 6 or 7mm but a std allen key will fit if you aint got a 'socketed' one.
standard ones fit, just the socket is a bonus for when doing/undoing them.....
It is a 7mm allen key or hex socket. Did mine a month ago :thumbup:
I found that when I changed my disks I used a philips socket and they put up very little resistance...
