Boost guage fitted!!!
how much are they ?
Looks tidy :thumbup:
yes those gauges prob do stop the noise but as said quite expensive :)
Right iv nearly fitted it! Just one thing how the **** do i get the PIPE in from the engine bay! cant find anywhere!
is there an easy solution ! HELP............
  • 9 months later...
that is one of the next things on my list of things to-do !!
Recently fitted one to mine :P Total cost about £25
29831.attach
29832.attach
Pin 2 on the headlight switch is an ignition live.
I've pulled the headlight switch out but the pins arent numbered, is it literally second from left? If I am looking at the Haynes wiring diagram for the headlights can anyone tell me what I'm actually looking for - it isnt obvious to me but would like to understand what I'm looking at so I can get me VDO gauge sorted:confused:
Thanks, John:)
hay guys,anyone suggest a good way to put the hose through the bulkhead ??
also you can get a hepworth sdw1 55mm plumbing joiner for about £2 and its just about perfect to make a pod out off.just need bit of insulating tape round back of gauge to make up the 2mm.
It looks good. :thumbup: but I can't see the point of showing negative boost for a diesel. Surely having no throttle valve it will not go into - numbers. Am I correct in saying this?
You are correct, it's just a cheapo gauge. I have an HKS with no negative scale on it which was better, but it turns out they dont work very well after you drop em :P
