Getting my 4 digit login code!
I really need the one for the white mongrel 2.... The program I did have does not seem to work right. Anyone know of any software I can use to access my car and find this number? I really don't want to have to go to my dealer and get all coding work etc done by them = ££££!!!
i take it your using VAgtacho right?
What version are you running?
cheers
John
whats the code for?
whats the code for?
Coding Keys, Immobilisors and ECU's
cheers
John
I don't know, but Skoda isn't even an option - Any chance someone else can send me something, perhaps via MSN? ;) Would be good if proven to work on Fabia vRS platform. :D
You'll need to buy, or find someone with Vagtacho software & a lead near you.
I bought a lead off ebay & downloaded the software for free from the internet.
This allowed me to obtain the SKC from SWMBO's Fabia after a few tries.
See the attached PDF file for details.
As a bonus this also allowed me to enable "permanently lit needles" and the "miles to empty feature" which was not there as standard, on my Golf.
I reckon it's probably worth buying a cheap lead and software (for all it costs) just to have "in your toolkit" so to speak.
HTH.
vagtacho.pdf
I would only need the correct software as I already have a vagcom lead which will do the communicating for me. :)
You will have trouble using a genuine USB vag-com lead with 'tacho.
I have a genuine serial port lead, if that matters?
Not to worry though as I've found a local friendly VAG specialist who has it, so chances are I will just go visit his outfit with the white one. :)
use vag-tacho.:D
if its keys/immoboliser you should be able to do it with vagcom if not i would point at vag tacho.
