hi guys new to this, i have a skoda octavia 19sdi 03 can any one help
can someone please help with a digram or pict of my gear linkage and rods mounted on top of my gear box as i have no gear and ther is alot of movement in my gear stick im not sure if the mount the rods connect to is bent as tried every possable way and can get top gears 1,3,5 but no bottom gears this is our first skoda and it puzzeling me as the gear box its self is fine, i would be real greatfull as this is our family car:(
Welcome to Briskoda.
Best to place this querie in the Fabia 1 section.
Hope this helps??
Hi
This is an Octy querie , so may be better in Octy section rather than the Fabia ;)
But be aware that the SDi Octy did have major problems with the gearboxes on these , and if I remember correctly (IIRC) then the lack of gear selection could be something to do with it
I am sorry , but it could be bad news
I hope not for your sake as it usually means new gearboxes
I will await someone coming along with a bit more knowledge on this
Sarah
oops sorry mate. :o:O
Hello and Welcome.
Might be worth getting the linkage cables adjusted. Otherwise, you're looking at a reconditioned box as a replacement.
welcome
hi guys thanx for the welcome, its great to no we have forums like this, managed to get it sorted it was the stablising bar that came out of the gear stick rod, pushed it back in and all was fine, back on the road again, with no cost thanx to all for help:thumbup:
