Interesting VAGCOM code
I ran a VAGCOM scan on a Mk4 Golf 1.8t for someone the other day.
Address 01 -------------------------------------------------------
Controller: 06A 906 018 CG
Component: 1.8L R4/5VT MOTR HS D02
Coding: 04000
Shop #: WSC 01271
9 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
00561 - Mixture Adaptation
14-10 - Adaptation Limit (Add) Exceeded - Intermittent
00575 - Intake Manifold Pressure
11-10 - Control Limit Not Reached - Intermittent
00543 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :-)
01249 - Fuel Injector for Cylinder 1 (N30)
26-10 - Output Open - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
01251 - Fuel Injector for Cylinder 3 (N32)
01252 - Fuel Injector for Cylinder 4 (N33)
Readiness: N/A
I thought the smiley was a nice touch!!
It's an import from Singapore with a few mods and presumably the rev limiter mapped out?
Isn't it some thing like if the revs exceed X amout of seconds on the limiter that code is triggered.
I may be wrong :)
Yeah, I'm sure it's something similar too Fatty.
Love the smiley touch :rofl:
Steve
Seen that one before, there was also one about somone in the boot or something posted a while ago but I can't remember exactly so I can't find it.
Top work! :thumbup:
:rofl:
