Interior light
I have a 53 plate VRS and my linerior light doesn't work at all. Was wondering if there is anything I should look for or any ideas on what it maybe. Thanks
I would replace the bulb. Does the glovebox light work? and the rear load space light (if fitted).
Yep, looks like you'll need a replacement bulb.
If all three lights in the front do not come on (the middle light and two map reading lights at either side) it sounds more like a blown fuse. Or possibly a poor connection into the light unit (less likely). . .
Just checked bulbs look ok and the glovebox light is not coming on either.
Where is the fuse located? Only just had the car not sure where anything is yet
Just checked the fuse and it has blown, thanks.
Well done, anther happy customer :D
