alternator light problem
The alternator light is stopping on all the time even if I don't have any thing turned on while the engine is running the light stays on. I have also tried a second hand alternator on recently and still no change could do with some ideas thanks.
Moved to the appropriate forum
The alternator light is "voltage out of spec", not just "low charge". You say you've changed the alternator; have you changed the control box!?
If not, check the output voltage ASAP, before you fry the ECU!
