205 50 17 tyre pressures?
i have just fitted some pirelli corsa tyres to my octy 1 vrs which are 205/50/ 17 and just wonderd what pressure i should have in them :confused:
Same as what it says inside the fuel filler cap, std size anyhow.
I run mine on 32 PSI.
I run 33 in the front and 30 in the rear personally.
Just play with the pressures and see what you get on with. Anything between 29 and 35psi will be OK.
Or just follow what Skoda say, like Lummox said.
Start with what Skoda say, and look for any signs of them acting like they're over or under-inflated after 3 or 4 thousand, then adjust 2PSI if necessary.
