vRS Water Pump ???
OE or not ?
i work in parts, and im pretty strictly OE with regards to most parts, however i see on here some people dont rate it
I had an OEM one fitted when I had mine done for two reasons: first, the design's been improved in the last few years; second, the whole 'metal impeller' thing came about due to a spate of failures on VAG 1.8Ts which are a lot more prone to that sort of thing apparently - failure of the water pump on a 1.9TDI is practically unheard of... :thumbup:
Any more info on those changes? I went for the metal version when I had my engine changed as it was available, and it just will not fail as likely :)
I am going to fit the metal impellor one.... genuine Skoda... if you hand in your own unit they will give you £25 for it ;)
cheers, genuine ordered !
Err, Skoda never made a fully metal one???
That is what I thought as well, and although they may not fail on the PD, I did not fancy taking the risk at the time the cambelt was changed and paid the difference to get a metal one instead :)
I always fit genuine, never had a problem with new plastic ones and ive only ever seen one TDi water pump fail.
Will they just pay you £25 for your old water pump? If so, I know where I'm going to soon! :rofl:
yeah aslong as you hand it back in within 3 months of buying a new waterpump!! so no good if you just have one lying around :rofl:
and mines is metal impellor and i got it from skoda... can get pics and prices if anyones interested :thumbup:
You might have bought it from a Skoda dealer, but it won't have been a part listed on ETKA ;)
mine came today, plastic impeller
I'll get the details for you :thumbup:
also, i dont remember seeing a gasket in the box with it ?
do you use some sort of instant gasket with it ?
It should have a rubbr o ring around it.
yup, checked and it does cheers
