bad "to the left" pulling
i have pretty bad pulling to the left.
anyone had this problem and found out what is causing it?
could it be the front arm bushes??
cheers
there are loads of threads about this issue
main cuprits are the bushes you mentioned
tyres can cause it too, mine drove spot on with Michelins fitted , as soon as i fitted a pair of Dunlops to the front , it pulled badly to the left
so check your bushes , if in doubt get them replaced , then a 4 wheel alignment is a must
word of warning though , they do tend to pull/drift to the left , some worse than others
get your tracking done, the one ive just bought was doing it, mentioned it to the seller who took it the garage, they did the tracking and its ok now
Mine pulls to the left and i've just had new powerflex and solid cupra bushes fitted along with some other suspension stuff, i put a thread up about it a while back and alot of people said they had the same issue. I had the tracking checked and it was fine so i wouldn't worry about it.
