Octavia vRS PCD - 112mm or 115mm
Hi
can someone confirm if the octavia II vRS is 112m or 115mm PCD as i've found threads saying the octavia II is both of these sizes
also am i right in thinking 112mm PCD wheels would not fit on 115mm hubs or would i still be able to get the wheel bolts in?
Cheers,
Dan
definitely 112 - 5x112 :) usually a 2mm difference can be overcome with "wiggly bolts" but I don't like the idea and think 3mm is too much to overcome safely. I assume the hub diameter is the same 57.1mm across the VAG range.
5 x 100 for Octavias 1997 onwards
5 x 112 for Suberbs
The new Octabia might have the same PCD as the Mk5 Golf? and later Passats have 5 x 112?
If your totally flummoxed why not ask Mr Lummox
Click on this link below and it is invaluable source of info
Alloy Wheel Fitting Guide - FREE guide to correct alloy wheel fitting
Edited by Banana-Man
new octy 2 shares same stud pattern as golf mk5 and the passat & superb. I also believe the Audi A4/A6 & maybe A8 have used the 5*112 for many years, whilst 5*100 was still more prevalent (mkIV golf and octy 1 / Audi A3 / Ibiza)
