thermostat
can anyone help please, my temp gauge needle is sitting at the bottom of the gauge constantly, i have the haynes manual and read how to change the thermostat, which i went and brought, it came without a gasket which i then went to a skoda dealer and they imformed me i need to buy the complete housing, could anybody tell me if i need just the thermostat or the complete housing and if indeed it is the thermostsat that could be the problem many thanks
Hi there, it helps if you post which model Felicia you have. My themostat and housing I got here http://cgi.ebay.co.uk/Skoda-Felicia-1-3-Mpi-Thermostat-BRAND-NEW_W0QQitemZ400014400282QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item400014400282&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 they are a reliable seller.
Your housing maybe broken internally so the stat is just floating around, mine was. Replace and you should see your gauge rise again. You may also want to check the sendor unit that sits in the top of the housing, I replaced that as well, now the gauge sits at the halfway mark.
Check this model stat housing fits your model, mine is a 99' 1.3mpi. Ask seller he is a skoda specialist spares seller.
Mick
sorry guys, its a x reg 1.3 felicia estate petrol engine
Mick
i'm sorry to disagree, i checked out the picture and its the same thermostat as the one i need to pu in in mine, i have no thermostat and the needle goes 1/4 up,(80 degrees) and if i dont set the mix to lean its 75 degrees
your sender is simply not working, its on top of the same housing, should have blue ribbon in the bottom and is held down by a small clamp with 4 wires coming out of it
That sounds right. When my broken thermostat was removed the gauge moved to around the 1/4 mark. Everything still worked. Apparently, because of the poor thermostat design they often seize in the closed position after breaking up causing an overheating problem. I don't know if you can get a sensor from a non dealer source but Skoda dealers seem to offer complete assemblies only.
what they sell you in the dealer is what you see in the picture, the thermostat never comes alone since is kinda fixed to the assembly.
the temp sender is another part and it comes with a yellow and a blue ribbon, they both fit the felicia, but if you dont fit the correct one it doesn't read whell, if you dont have a reading at all, thats the part that you will need to replace
