Climatroninc settings in radio display.
In the Octavia with climatronic and radio Stream or Audience do you get the clima settings in the radio display when you are operating the climatronic.
Do you also get them in the display if the car is equpped with navi Columbus?
In the new Superb, Passat CC, GolfVI, you get the settings in the display. But those cars have a new climatronic unit.
I wonder if it is possibel to get the clime settings in the RNS510/Columbus display on a Tiguan, which have the same climatronic system as a Octavia.
Is there a vagcom code maybe for this feature?:confused:
The settings for showing on the Stream/Audience are actually in the head units options screen rather than through Vag-Com. Why not give that a try, it could just be turned off.
yes. It means that the climatronic unit is sending out signals to the central unit about clima settings. Those signals should also be avalible on a Tiguan or Passat. But they are not easy to find
As written in another forum already, not supported by the components you got.
  • 2 months later...
I've make the change on VW golf V but doesn't work properlly.
Any help??
You already quotet the only answer.
Yes, but now I've got mounted the new clima from MKvi, on my MKV. No help?
Pictures? Scans? Even if what you are saying is true you would need to switch the RNS510 to BAP instead of DDP, but by doing so you will loose phone support and the instrument cluster won't show anything anymore as well.
Here's the photo
What is BAP and DDP??
Now the real question is, does all the rest still work? And by that I mean all climatronic functions, flaps, sensors as well as compressor and such? Also do you still have phone support and does the multi-function display work as well? I still have some serious doubts here. :) Last but not least there is the question for the Auto-Scan. :)
BAP = Bedien- und Anzeigeprotokoll, DDP = Display-Daten-Protokoll
phone & multifunction (from MK6 too) working perfect. Clima works ok, but when I press the AC button on clima, it turns crazy, flaps get crazy... muy basic setting can solve it. The compressor for cold air doesn't start. I've been checking elsa diagrams are the same for mk6 than mk5. any help??
air quality sensor is still not installed, tomorrow maybe... do you think this can be the problem???
This are the error codes from clima unit:
Monday,16,March,2009,18:38:39:05456
VCDS Version: Beta 812.4
Data version: 20090214
Address 08: Auto HVAC
Control Module Part Number: 5K0 907 044 A
Component and/or Version: Climatronic 120 X040
Software Coding: 0000000000
Work Shop Code: WSC 00000
8 Faults Found:
9472882 - Motor for Fresh Air / Recirculated Air Flap
B108B 72 [009] - Actuator stuck open
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 84
Mileage: 93 km
Date: 2004.14.02
Time: 23:26:10
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 97
Date: 2007.14.01
Time: 10:26:31
13701488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 245 km
Date: 2009.14.19
Time: 11:05:09
13701504 - Function Restricted due to Missing Message(s)
U1111 00 [008] - - - MIL ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 245 km
Date: 2009.14.19
Time: 11:05:09
13701520 - Function Restricted due to Missing Message(s)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 245 km
Date: 2009.14.19
Time: 11:05:09
13701536 - Function Restricted due to Missing Message(s)
U1111 00 [008] - - - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 245 km
Date: 2009.14.19
Time: 11:05:09
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 243
Mileage: 64687 km
Date: 2000.00.00
Time: 18:32:45
any help about this???
Well, not much help - those codes are pretty clear. Due to missing messages from other modules its unlikely to ever have full functionality... Nothing we can help with there I think.
Hello Sebastian, what you say is right, but I've been checking at ETKA, all parts from MKV and MKvi climatronic and all are the same. The only different is that my cars doesn't has the air quality sensor. Do you think can be this??...
The problems is that when you press AC button the compressor doesn't start working, and flaps gets crazy. All the wiring comparing with ELSA diagrams are also the same.
Thanks for your answers.
Could this be in any help?
Climatronic on screen - Page 3 - VWnavi.com
Seems to me you got to do some rewiring.
the wiring problem is now ok, but compressor never starts..... No cold AIR, when I press AC button nothing happens.
