Tailgate trim removal
Is there an easy way to do this? without damaging the trim / paintwork etc
Does it just prize off? (i.e. there are no screws - I can't see any!)
And how easy is it to replace?
CHEERS
Stuart
03 Fabia Hatchback Silverline
It's a very tight fit and most trim removal tools will bend before they release the clips. Protect paintwork with a piece of card, then using a large flat blade screwdriver, prise away the lower corner, then pull hard by hand to release the clips. Some will break, so have a few spares ready.
Sounds like a job for a professional (or rather "someone more hady than me!")
I used to do some work for a company that fitted alarms and sound systems to top end motors, usually just out of the showroom. It was nerve racking stuff. One single mark on a bit of trim, and it could cost hundreds of pounds for a stupid piece of plastic.
The classic one was someone, drilling five holes through the top of a petrol tank while fitting rear speakers :rofl: That was on a Subaro and the rear axle had to come out to change the tank. :D
You talkin about the rear bump strip? Mine came off without any probs with a bit of wiggling, sprayed it purple and stuck it back on again just clicked back in
I think (and hope) the OP meant the tailgate inner trim panel. :thumbup:
Yes - its the inner trim - a big piece of plastic with a vice like grip!
lol leave it alone and dont be so vain! :-P
They are really tight but they will lever off. As said before, be prepared to buy a few new trim clips and be prepared that it is just as tricky to re fit!
Let me guess. The rear washer pipe has popped off?
i did this last weekend, just persevere and use a flat blade screwdriver wrapped in insulation tape to prevent scratching the paint. start at the sides and work to the lock area.
Getting it back on is more tricky i found...a case of 10 hands needed.
Good luck, and watch out for the plastic going white as you are bending it, a tell tail sign that your stressing it too much.
