Oil pick up in the sump
Is it worth replacing as a servicable item as I know they can get munged up and cause all sorts of problems, I'm approaching 85k and just wondering if it's worth doing.
Also would it be worth doing an engine flush, if so whats the best way of doing this ???
TIA.:D
Years ago used to flush engines all the time, not so much now as oil quality has improved.
That said we have had a couple of Pug 307`s blow their turbos due to oil starvation:eek: we normally replace the oil pick up pipe (sieve) and all the other oil feed/drain pipes. The sieve is normally gunked up.
So yes in answer to your question, if your not sure on oil change history
HTH
Phil
If your not sure on oil change history
Every 10 k on the dot. Would it be worth whipping the sump off at the next service and having a look or just get it done anyway.
Have you had the car from new? My 03 plate (from new) has always had Synta gold in it after swapping to 10k servicing after its first service..
Up to you really, if you do the work yourself then why not...might be worth PMing Lummox
Phil
Hi Fatty
We have at the moment a Leon in having that work done to the sump , as he has a problem with the pich up
We do oil flushes too at £9.99 + VAT to go with servicing and have seen some responses with it
So maybe you know , it could be worth considering?????
Next service , may be wirth an oil flush too
Sarah
Might be worth checking it. Mine gunked up at about 89000 miles which caused a dramatic loss in oil pressure and an abrupt end to my track day :mad:. I was lucky though as I switched it off pretty much straight away and didn't cause any further damage.
