How many locking wheel bolts.
Hi,
I've a L&K Octavia, which I purchased end of last year new. I've just noticed that only one of the four wheels has a locking wheel bolt. In otherwords the three other wheels aren't secured.
Is this normal? Certainly isn't on other cars I've owned.
Thanks WipeOut
normal on all the cars ive had. normally you buy them in a pack of four and then one is for each wheel.
It should have been supplied with 4 locking bolts, one on each wheel as stated above. Do you have covers over your bolt heads (my VRS does)? If so have you taken them all off to check for locking ones? It may sound obvious but the covers do look a little like bolts so your problem could be you are just missing one of the covers!
Hi,
Thanks WipeOut
No, that ISNT normal - it should have four - one per wheel with the four standard bolts also present on each wheel. :(
As PSM says, do you have a full set of bolt covers?
