Felicia Diagnostic Connector
Anyone know the location of the Diagnostics connector on the Felicia?
It's a 1.3 LXI,
Ta
just under the dash on the drivers side, by your right knee
I take it the Felicia uses the single 16 pin connector and not the 2x2 connectors.
Does anyone have a picture of it or can explain in more detail as apparently it isn't obvious.
Standard 16 pin OBD connector
ok can't find the damn thing Grrr
If you look under the bottom lip of the dashboard under the steering wheel you should see it:
Ta I found it in the end...
Oddly enough the car has two problems:
1) G28 engine sensor intermittent fault 00513, so any info on where the sensor is or common issues with it would be appreciated
2) Alternator light is on and glowing, brighter when revved, car has had new bushes so any suggestions on that.
Sorry to alter the thread subject a bit.
