Best karcher?
I can post up a picture this evening when I get home but you simply just file down the brass connector until it fits, takes time as you have to file 4 bits but works well.........:thumbup:
:thumbup:
Any luck with them there photos of that there brass thingy? :thumbup:
Apologies for the delay but if I am being honest I completely forgot, here are some pics that I managed to take this morning before work:
You can see that the two prongs on the brass connector are slightly curved and these edges were square but I have had to file these areas away for the connector to fit into the Powercraft lance and then rotate freely to lock in place........:thumbup:
No leaking and no problems...........:D
Does it have hozelock fittings?
I would expect so...without fail!! But to be on the safe side i'll let you know today when it arrives :thumbup:
Also, will a karcher fitting foam lance fit?
Snow Foam Lance
If you look at the bottom..you can see all the different adapters...just chose which one when you order :)
Bought a Karcher K236 with patio cleaner brand new off fleabay for £70 last week, superb kit and patio cleaner is good for the path too-bargain:)
