ABS pump fault - 01276
The fault appeared after the car had been stood a month over Christmas, the battery had been removed (for charging). I am thinking abs sensor (should I say hoping) has dirt/rust on it.
Car is a 51 2001 Octavia VRs
Wounded if any one out there has had this fault and can tell me what to look for. I have found the info below and will be trying out some of the solutions suggested.
All help much appreciated
01276 - ABS Hydraulic Pump (V64)
01276 - ABS Hydraulic Pump (V64): Signal Outside Specifications
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • ABS Hydraulic Pump (V64) Connector to Control Module faulty
  • Wiring and/or Connector(s) faulty
  • ABS Hydraulic Pump (V64) faulty
  • Brake Electronics Control Module (J104) faulty
Possible Solutions
  • Check ABS Hydraulic Pump (V64) Connector to Control Module
  • Check Wiring and/or Connector(s)
  • Check/Replace ABS Hydraulic Pump (V64)
  • Check/Replace Brake Electronics Control Module (J104)
01276 - ABS Hydraulic Pump (V64): Electrical Fault in Circuit
Possible Symptoms
Possible Causes
  • Fuse(s) faulty
  • Wiring and/or Connector(s) from/to ABS Hydraulic Pump (V64) faulty
Possible Solutions
  • Check Fuse(s)
  • Check Wiring and/or Connector(s) from/to ABS Hydraulic Pump (V64)
Retrieved from "http://wiki.ross-tech.com/index.php/01276"
