Impreza alloys for the Fabia.
Hi all.
Joined this forum a few years ago when i swapped my Mk4 Golf for a VRS Octavia but then swiftly had to sell the Octy due to money issues, But i'm now back and need some help!!!!!
We (misses & I) have recently got a Fabia. I'm looking at alloys as it only has steelies but do not have a lot of funds avaliable. I've seen some alloys from a Subaru Impreza (not the gold ones) and they going cheap.
Having looked at a few alloy fitment guides online im unsure weather they will fit ok.
The allos fitments are:-
PCD 5*100
Offset 35-52
Bore 56.1
Am i right in saying that ill need spigots for the bore size?? (Fabia 57.1) I'm also lost when it comes to the offset as it says the Fabia offset range is 35-38.
(Deleted now I've thought about it. Durr...)
I'm not "that" technically minded but a 56.1mm bore wheel will not fit on a 57.1mm hub. It's just too narrow. However, not by much so a machinist could probably take out 1/2 a mm all the way around the inside of the alloys, using a lathe.
I apologize for my stupidity!!!! Was thinking of the bore size round the other way!!!
But on my other note what is the most you can go in terms of offset? (et)
cheers
Between 35 and 45 is about OK on a fabia
I could lay my hands on a set of OEM Fabia standard alloys cheap if you can't make Scooby alloys fit
PM me if you're interested :thumbup:
